1 - 2 of 2 Posts
Check any fuses or relays that are in the ABS system. Check all the connections. Have you done anything to the car recently, or has anything odd happened, like rearending a tree?
It could be the ABS pump, a wheel sensor, or a relay. Unless the key turn switch trick works in this situation, you may need to hook up to a scan tool to tell you the specific error code.
1 - 2 of 2 Posts
