hello to all...I have just top up my AC last week all was work well ...well today when I turn the unit on i go cold air then hot air, this happen over and over....and when driving the car it was like something turn on and off car was driving odd was get like power sifts or something like that .....turn the AC off and car was driving ok power returned to normal...check for codes and at this point zero codes....was think my be AC pully ...look for help thanks
I'm no A/C expert but since it was affecting your engine power, I would think it has to be a problem with your compressor. Perhaps it is locking up periodically and causing the engine to struggle. Hopefully one of the A/C experts here can give you some more info.
Sounds like its either low on freon causing the compressor to cycle on and off quickly, explaining the power loss feeling, or the thermostatic switch is not working, and the evaporator is freezing. Have the a/c tested for leaks.
