1 - 9 of 9 Posts
I have a '01 Intrepid R/T, with Infinity System, but I want to change the stock rear 6x9 speakers, I'm using all the stock sound system but the rear speakers are starting to sound bad. What do you recomend me to buy. I was thinking about de Infinity Kappa 693.7i (6x9 3-way) Please help me with this.
Does the stock amp will power up this speakers ???
or which speakers I have to buy ???
i have the infinity kappa 692.7i's and they are fuc*ing awesome....and yes, they are a 2 ohm impedance...i would strongly recommend those, as many other members here would also
bUT do you have the stock HU and amp with the Kappa 692.7i's ???? or do you ad something ???
I would add an amp to all aftermarket speakers, the Factory amp is weak to power any other speaker, and plus it has crossovers and other bullshit that the factory 2-ohm speakers need to work as a component system, I would bypass them, or just buy replacement O.E.M. Infinity 6x9's until your ready for the upgrade pal!, ;),
Those are 2ohm, so yes they will work. You'll need the wiring adapters to avoid cutting the factory harness. They are free with the speakers at crutchfield.com
They will technically work BUT performance will not be good. The Infinity amp has a crossover and I think it also has a custom EQ curve programmed in that is designed to match the stock speaker. If you put a speaker in with different tonal characteristics, it won't sound right.
LOUD98ES said:
Replace everything, and amp it all with new amp(s)
I agree, get rid of the "premium" Infinity crap. I currently have the "premium" system and all the speakers sound like crap now. They sounded great for just over 2 years.
I have everything for a new setup and hope to put it in soon. I bought 5 1/4" components with 6X9 plate for the rear and 6 1/2" for the front. All I need is another sub and I am set.
1 - 9 of 9 Posts
