1 - 14 of 14 Posts
Can someone give me a step thru on how to remove a dash on a 98 with the auto-temp?
I think that there is a loose wire on the autotemp unit, and I was wanting to look for myself before giving a donation to the local dealor to re-hook a wire harness.
The unit does work from time to time, when the car hits a bump, or sometimes when I tap on the dash, so I am sure that there is just a loose wire.
Thanks for anyones help that they can give me!
Sounds more like a ground problem to me.
Anyways...
Take the shift knob off. (Hex wrench)
Take the shift boot panel off. (Just pull up)
Take the radio trim off. (Just pull forward its only clipped in there)
Look for your wires. These will be connected to the harness. If those are all ok, you may have a more serious problem. Where are you in central Iowa? If you are close enough I might be willing to come over and help ya with your problem.
--Gorm
Ok, thanks for the info Gorm.
I live in Ankeny, just north of Des Moines....but get this..
I was just in Amana this weekend for the renaissance fest...timing is everything!!! :biggrin:
DUDE
That is awsome!
I'll bet you drive through a town called High Amana, The highway goes right through with barns and houses. I live up on the hill the one with the house with the big deck....
That is cool. You didnt happen to see a grey Intrepid with 300m 18's driving around while you were here did ya?
--Gorm
No, I missed that car, but I was spending the day in tights...lol
I am a performer in those festivals, that is why I was in town.
I did see alot of houses like that near the festival grounds, not sure what towns we went through though, I was not driving that day..
Thanks for that tip as well Chicago.
I appreciate the fact that both of you responded so quick to my query.
I was hoping to do this on Saturday, so I posted early to make sure that someone responded. Now, with your quick help, I am about to head outside with Tools in hand....just have to make sure that the wife does not see me...
Just my job till 5pm.
If you are coming late in the day, I would appreciate the help.
Oh, I should be at Ames at around 2-ish. I kinda doubt that i will stick around as I have a funeral in the morning to go to that i have to be a casket bearer in. (Best friend, head on collison). So i probably wont be in "working" clothes.
Although last time i was stuck in Akeny, i ended up finding a chrome and leather shift knob at a junkyard! :)
--Gorm
Its all good.
With the tips you provided, and the one for the other walkthrough, I think that I should be ok.
Don't forget to put the car in Nutral. LoL
1 - 14 of 14 Posts
