· Registered
I have a 95 Intrepid ES I need to sell. The car is in decent shape and runs and drives out real nice, with 111k miles. Only defects are 1) a/c doesn't work (probably compressor) 2) neutral safety switch is goofy (sometimes have to jiggle gear-shift to start) and 3) radio doesnt work. I owe $5000 on this car but would take $3000 as I need out from the payments, but have no more in savings to pay it down. Which of these seem most critical to have fixed to make the car most likely to sell? Any good ideas appreciated!
· Registered
you could fix the radio with one from a junk yard cheap or else you could put a cheap Jensen tape in both for 50 or less assuming of course that it is just the radio. But I would check out the starting problem. If you can hold off until later like fall once it cools off most don't think about air then. So you could sell it easier.
