A year ago I purchased a 1994 Eagle TSI,which I`ve spent the better part of a summer putting back to its former glory.
The car has no known issues at time being,however I want to get the timing belt replaced,as no one really knows the last time this was done.
I am fairly confident with taking on the job myself,specially seeing as this cost closer to 3000$ at local automotive shops (yes,really.)
I shall be buying my parts at Rock Auto,and would like to avoid returning wrong parts,
so I was hoping someone with experience from this job could provide some insight regarding the following;
1. I am looking to purchase a kit,any experience with this brand?
Gates
Are there better alternatives?
2. Kit does not include cam. tensioner hydraulic assembly.
Do I absolutely need to replace this component,or is it possible to re-use the old one,giving it is not warped or damaged?
( My Haynes manual makes no mention of replacing it during the timing belt replacement.)
3. I see a oil leak coming from somewhere around the existing hydraulic assembly.
Not so much as to need refilling the engine,but some stains under the front cradle.
Should I consider adding some camshaft /crankshaft seals to my order?
Or is this a procedure which could cause further oil leaks.
I would be comfortable exchanging the crankshaft seal,but uncertain about the camshafts,as I would not mess with the timing.
4. Any other components it would be wise to replace at the same time,seeing as this much of the engine is already removed?
( Of course I am doing the waterpump)
Any insights and advice much appreciated:)
Thanks for reading.
Discussion Starter #2
My apologies for posting in the wrong forum,I can`t seem to delete my thread.
If a moderator could move it to the correct forum,I would appreciate it,
thank you.
Gates is a good brand.
I would def suggest a new Hydraulic Ten.
Without cleaning that area well, then re checking for leak be hard to tell.
Cam seals are a PITA, I know the passenger side bolt requires you to jack the engine up a bit to get it out (super long) Never did a crank seal.
I highly suggest though once you've done your timing, rotate the engine over twice by hand and recheck all marks.
Seeing as the leak appears around the tensioner,it would be typical luck if it stems from the cam seals.
I will have a better opinion once all is taken apart,just wanted to have the necessary parts on hand before doing so.
The seals are not a costly part,so maybe I will purchase both just in case.
Do you think I can get away with any kind of tensioner (as long as its produced for the car in question),
or must I have the specific Gates tensioner to go with the Gates belt?
Sorry if my question seems redundant.
Many thanks for taking your time to shed some light.
I do not think any brand needs to work in conjunction with any other. I would also of course replace the idler if you haven't already.
