1 - 9 of 9 Posts
I just got done changing the oil, flushing the radiator, installing a tranny cooler, putting in a K&N air filter, and doing a tune up on my 95 Vision. What other maintenance work can I do to the car to make the engine and tranny run stronger and longer? Everything is fine right now thank god, but I wanna make sure it stays that way before I start doing all the cosmetic work to it.
Dain bramaged
the 3.3l motor is as solid of a motor you'll get.. even if you abuse it..
i have a caravan with a 3.3l in it with 192k on it.. still runs like new..
as for the transmission.. drop the pan, change the filter and then do a flush with atf+3 (or +4 if your feeling spendy)
oh and if your front end "clunks" change your sway bar end links..
Well I change the oil religiously, the Eagle is running strong at 135,000. I want the car to last me a while that way I'll have enough money to put a new motor or tranny in if god forbid something goes wrong.
1 - 9 of 9 Posts
