1 - 10 of 10 Posts
Need help,
My 2001 trep has an airbag light and the horn and cruise control are not working, everything else is perfect. How can i fix these things.
Thank you
That rhythm is INFECTIOUS.
Sounds like the clockspring went south on ya... It's right behind the steering wheel - which will need pulled off to access.
so what can i do, do i have to buy a new clockspring or what. Can i fix it myself or i have to take it somewhere. Thanks
You can buy one from a dealer and pay for it dearly or buy this one http://cgi.ebay.com/ebaymotors/2000-CHRYSLER-300M-CLOCK-SPRING-W-CRUISE-SWITCH-_W0QQcmdZViewItemQQhashZitem483e40ccdcQQitemZ310282079452QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
This was the cheapest one I found with a quick search. Probably as cheap as you will find one. Then buy or borrow a steering wheel puller.
Try using the search button and look around for a how-to for this project. If you can turn a wrench you can do this yourself.
edit: here's a how-to http://www.dodgeintrepid.net/showthread.php?t=38095
the one on ebay, it says for chrysler 300m 2000, will it work for my intrepid 01 though.
Thanks for the help
I had to replace mine b/c of the exact same issue, and i used that how to and everything went fine.... if i remember right, you should need the 7 wire clock spring as supposed to the 5 wire one.... i got mine new from dealership for around $60..... well worth it b/c the air bag wont work when the light is on....
1 - 10 of 10 Posts
