41 - 46 of 46 Posts
Our new compressor :) A 80gal 5HP Devair Its so huge and amazing!! Love it ^-^ my dads a cunstom painter so he needed this bad also hs the hard air lines all over the wait and water and oil separators :D
Nice pump, something that size is a must for any painting, done regularly.
Discussion Starter #42
I still need to run the hard air lines. I hate running the hose up from the basement and it doesn't pull as much water out as metal pipe.
The only problem with mounting the air compressor in the roof is heat, you may overheat the compressor or the motor , depending on where you live!
41 - 46 of 46 Posts
