It first started with the rear pass window. Then the rear driver. Now its the front pass. They no longer operate. The drivers window still works.
Is there some type of fuse for each window that may have blown that I can check? Or perhaps something else I could look at before I'm forced to take it to the dealer? :(
its the switch, in the driver door, get it replaced from a junkyard. well first off check it out, mine did this same thing, it was caused from water damage from leaving the windows rolled down and it raining in the summer :p i replaced mine after noting the visable damage to the circuit bored with some from a newer concorde and the switches from the concorde already had something covering the pins to prevent moisture damage
When you say its the switch in the drivers door what exactly are you talking about? Which switch?
And can anyone tell me how to remove the door panel to access the switches?
