What is the part number for a 1995 Intrepid stock alternator?
How many amps does it put out and at what rpm?
Are there any drop in replacements for it with an EXTREME amount of amp output?
Is there a webpage somewhere that lists the specs of the stock alternator? I can't find anything anywhere about this alternator.
Thanks for the help guys.
I think all Intrepids comes with 120 amp alternators. RPM info is very hard to find, but most modern alts should produce a fare chunk of their capacity right off idle.
If you want more juice, rip a police alt from a junk yard if you can. Mine's rated at 160 amp @ i dunno amp; 120 amp @ 800 rpm idle.
