1 - 14 of 14 Posts
· Registered
My amp keeps blowing fuses for some odd reason. THe gain is only half way up and all the connections are good. Any suggestions?
· Registered
I assume you mean the fuse on the amp itself is blowing?
I've had this happen to me once. It turned out that the fuse between the battery and the amp on the main power wire (which should only be located a few inches from the battery-you do have one of these I hope) was bad. I replaced that fuse and everything was fine. So I would suggest checking that. Hope this helped.
· Registered
lucky fuse :)
[ December 17, 2001: Message edited by: bat078 ]
· Registered
Is it a 2 or 4 ch. amp?
· Registered
what amp is it
brand, output, like that
what size wire do you have feeding it
are you running any other amps off the same power wire
does your amp get very hot when its running
answering that will make it easier to help out
· Registered
Had that happen to a Profile amp and the told me to send it to them and they fixed it. Contact the maker.
· Registered
Discussion Starter · #7 ·
Sony Explod 760watt 2 channel
4 gauge power/ground
it gets warm but not too hot
· Registered
It maybe that you have a bad ground, or that your ground wire is too long. Also how are you wiring the subs (assuming that this amp is just for your subs) are you running them in stereo or are you bridging the amp? :eek: :D
· Registered
Discussion Starter · #10 ·
no i checked that out
· Registered
Discussion Starter · #11 ·
oh yea, the subs are not bridged, the amp can't handle theses subs bridged.
· Registered
I checked your amp, I figure its either a XM-1902GX or a XM-1502SX. They are basically the same with just a little different features. Your 4awg is fine for that amp.
What brand are your subs and whats the ohm rating? How are your subs wired, in series or in prallel? Are the subs DVC? Improper sub wiring could be the culprit.
Chances are its the amp itself.
[ December 19, 2001: Message edited by: Thebulgd ]
· Registered
Discussion Starter · #14 ·
yea its fine
1 - 14 of 14 Posts
