Well I got it on mine, 59k. I was cruising at 65 on the freeway yesterday when it came on. For those of you who may wonder, no it doesn't slam into 2nd gear until you decel to about 40 mph. I pulled over, stopped the car, did the key dance to check the code, then drove off. Trans shifted like normal again but the MIL stayed on.
So I get home and pull all the TCM and PCM relays and fuses - light goes off. This morning, no problems getting to work. Coming home, same deal... comes on at about 60 mph. I pull over, stop the car at the feeder road traffic light, start it back up... everything is fine again.
Trans shifts smoothly in all gears, all speeds, etc. Torque converter operates smooth and breaks loose when it needs to. Speedometer works fine but I noticed a few months ago when it was colder it used to stick a little around 15 mph and then shoot up. Never had any other issues.
Right now I just pulled the input sensor and found a few metal shavings on the end. I cleaned it off but there weren't very many - is there really any benefit to this? This part looks like a simple electromagnet and it sticks to my fridge.
Trans fluid & filter was replaced at 30k and I was just planning to do it soon at 60k.
Any opinions? Do you think it's this sensor? I mean this is shifting as smooth as when I bought it new and came as a surprise.
Going outside now to reinstall and check the output sensor.
Thanks,
Tom
Thanks,
Tom
