1 - 13 of 13 Posts
I blocked off my EGR where it connects to the intake manifold, but the car still runs rough and throws a code for it. Should I disconnect the electrical going to the solenoid as well or block off the vacuum line from the manifold going to the solenoid? Any help is much appreciated.
Without the egr, you're going to get a code. connected or not.
Why did you "block it off"? EGR valve gone bad?
Remember, these cars are calibrated to run with an egr valve, it's part of the engine management system.
The egr valve is actually an important part of the managment system these days and works to improve power and driveability. It's not like the old days when emissions controls dragged the engine down performance wise.
Unless there's a work around I'm not aware of, the only cure is replacement for a bad EGR. Taking it off for performance gains is a myth from the "old days".
Cheers
BJ:anon:
I blocked it off after it kept throwing a code, not for performance, as a temp fix until I can get a new one. Anyone know how much they run at the dealer?
Yep, $ 122 MSRP at the dealer. Are you sure it's the valve, not the Vacuum Control Solenoid. What code is she giveing?
well, my egr valve for my 2000 2.7 cost just shy of 200 bucks Canadian. I would expect close to that range but not more. You may be pleasantly surprised with less.
Good luck
BJ:anon:
Edit: oopps. Strongt beat me to it with better info!
May not be the Valve, could be just the Solenoid. Just depends on the Code she's throwing.
Same ol' code 32.
Great White said:
Not sure about the 1st gen, but the second gen is a complete unit. EIther way, she's pooched.
cheers
BJ:anon:
Opps, my bad, your right !! It is one unit, I was thinking of something else.
Hold on a minute there strongt. I may be off base on this one
If you look at your post here:
http://www.dodgeintrepid.net/forums/showthread.php?t=70304
it looks as if the egr valve and and transducer are seperate on the 3.5 1st gen. Maybe you can buy them seperately.
Ryan, I'd check with the dealer if I were you. I think I'm begining to chase my own tail here!
Or maybe someone who's changed an egr on a 1st gen 3.5 can chime in?
Cheers
BJ:anon:
Cheers
BJ:anon:
No you was right the first time! They just sell it as a EGR valve and transducer assembly.
You can't buy them seperate. Only way to get rid of the code is to replace the solenoid. Blocking it off won't throw a code, if the solenoid works, I don't think.
1 - 13 of 13 Posts
