1 - 1 of 1 Posts
98 2.7.....Are the ports between the throttle body and upper plenum, upper plenum and lower plenum, and lower plenum to heads pretty close in size that porting would have no effect or is there some material that could be removed to increase airflow?? I'm going to pull it off eventually and look for myself, but I thought I'd ask first in case anybody knows.... Also any flash that could be ground off inside the runners or is this intake already pretty smooth inside?
Thanks
1 - 1 of 1 Posts
