how reliable is your ATC system and what errors are you getting?
  • Error code 34
    Votes: 1 100.0%
  • Error code 23 or 24
    Votes: 0 0.0%
  • Error code 27 or 27
    Votes: 0 0.0%
  • Error code 31, 32 or 33
    Votes: 0 0.0%
  • Total voters
    1
  • Poll closed .
1 - 1 of 1 Posts
I have a 1996 LHS with the ATC system. The AC stopped blowing cold air so I put a gauge on the low side port on the AC line, it gave a reading of mechanical problem and a 110 psi reading. Usually a properly charged system will read 25 - 45 psi, 0 - 25 indicates low freon and needs a charge,45 - 65 indicates an alert in the system, over 65 psi is a warning and a mechanical problem in the system. I did a diagnostic check on the ATC and it gave a 34 code which is engine temp message not received. I need some help on what would cause this message and error code. I would guess it's a sensor gone bad. Last year the AC blew ice cold and I recharged it at the end of the year and it was working great. I amopen to any and all suggestions on how to repair this as it is getting hot and I need cold AC. Thank you
1 - 1 of 1 Posts
