1 - 20 of 22 Posts
Ok..i have all the parts for autostick to be put into my concorde
Im putting it in on tuesday
any last minute tips anyone would like to give me
i have this
A/S pin-2 LG/RD goes to C106 pin-5 and then onto TCM pin-5 (Autostick Upshift Switch Sense)
A/S pin-1 YL/LB goes to C106 pin-6 and then onto TCM pin-44 (Autostick Downshift Switch Sense)
C106 is a Natural(White) colored connector located under the dash on the drivers side bundled with C105(Yellow) and C200(Blue). That's straight from my 1999 FSM.
is all i have to do is run the lg/rd to pin 5 and yl/lb to pin 6...is that all..or do i have to run wires to the tcm also
pictures would be greatly appreciated'
thanks
  • Like
Reactions: Wretched
thanks
from what I see, there is no difference, other than the length of wire used. Call me if you need help.
or could i just go straight to these wires
TCM harness for 98-01:
5 T5 20LG/RD AUTOSTICK UPSHIFT SWITCH SENSE
44 T44 20YL/LB AUTOSTICK DOWNSHIFT SWITCH SENSE
the harness coming out of the tcm
Take pics please always wanted to do this!!!
This is great, I'm in the process of collecting the stuff for an autostick in my LHS. So far I just have a 300M cluster, but there's no rush since the weather sucks right now and I have no garage to work in.
That is the route I used but first you will have to see if there are any wires in those posistions, my TCM harrness didn't even have pins in those spots of the connector, had to get two from a scrap harness, take the connector apart, and put them in.
the 300m is still in the yard that i got all the stuff for..if i need it..ill go get it
I'd check to see if the TCM connector has those pins/wires in first. Seeing as you have a 1998..they might be in there. Possibly cost cutting didn't take effect until later model years where they made different harnesses some with all the wires others stripped down due to less options. Were you able to open the pdf files I sent?
Considering none of them had it(i think) it may NOT be there in the first place.
Are you talking about the Concorde or all 1998 LH cars? The 1998 Intrepid ES had Autostick available so it had the wiring. Seeing as the LH platform was shared..there's a good possibility DC had just one harness for all models in that year. So it's worth a shot to look and save some hassles. Wouldn't you rather splice into a kickpanel wiring harness rather than go all the way out to the TCM? That's all I'm saying..nothing wrong with taking a look.
I talk about the cost cutting because my 2002 R/T has the wiring in the door harness for the courtesy lights but inside the car from the bulkhead there'sno wiring in the inside connector or harness for it.
Quoting myself from a couple posts ago, I have a 98 and the wire/pins were not there.
well either way..its goin in tuesday..i dont care how many trips to the junkyard i have to take..
and yes i wil take lots of pics
Discussion Starter #14
the one thing i have for me is i have the fully loaded LXi with the 3.2..so maybe just maybe they will be there
if the wires arent there..what did you guys do?
Discussion Starter #16
so that pink/red wire is one that you added?
That was just a reference pic to show where the connecotr pins go. I had already used the actual colours on my setup. It shouldn't matter what colour you use, as long as they go in the right cavity.
Discussion Starter #18
thanks a bunch man...by reading your other post..you said you didnt even need a autostick tcm correct?
so mine should be fine?
98's require that you change the TCM, In your case it can be from any 3.2/3.5 from '99-'01, or a '98 with autostick. 98 TCM's were either Autostick or Non-Autostick, '99-'01 will detect the cluster and switch by themselves.
Good luck!
  • Like
Reactions: Imadreadhead
Discussion Starter #20
Well today is the day...ill take lots of pics..and maybe we will finally have a how to on how to do this..
wish me luck
1 - 20 of 22 Posts
