1 - 20 of 34 Posts
Hi, all. First posting for me.
I have a 1996 Chrysler Concorde in need of either new inner tie rods, or inner tie rod bushings.
I have spent much time on Google, YouTube, etc., looking for ways to gain access to the retaining bolts, but the information I have seen so far hasn't helped much. Some have suggested removing the cowling underneath the wiper arms, and even the wiper motor itself, but I see little room to be gained by removing the cowling since it is attached to a protruding part of the firewall. Not sure about the wiper motor just yet.
This car has the big 3.5 engine (LXi model), and I need to remove the plastic air intake tubing behind the aluminum intake plenum before I can even get to the retaining bolts.
How can I get this (tubing) out? Will I have to remove a wiring junction box attached to the passenger side strut area first?
Be glad to post some pictures if need be.
Thanks!
You have to junk the whole car.
Just kidding. I know on the 2nd gen, which is the same rack, you do have to remove the cowling. Never messed with 1st gens. - someone familiar with them should be along shortly to answer.
:idontknow: - I just wanted to get my "junk the whole car" joke in. :)
Discussion Starter · #4 · (Edited)
As you can see below, the wiring junction box is in close proximity to the air intake tubing...
Vehicle Car Motor vehicle Auto part Engine
Here is a shot of the tubing itself...
Vehicle Auto part Engine Car Fuel line
Has anyone ever owned a 1996 era Concorde LXi model, and what procedure did it take to gain access to the inner tie rod bolts?
Discussion Starter · #8 ·
Many thanks, Scooter!
I saw some informative links and photos to pore over, but I haven't seen anything pertaining to removing my air intake tubing yet. I can loosen it from the plenum, but removing the tubing altogether seems almost impossible without removing that wiring junction I referred to.
I see no benefit by removing the cowling.
Try seeing if swinging the wheel all the way to one side or the other will give you an easier access point. On the 3.3 it is not that hard by just removing the coil pack and swinging the wheel to the left. On the 3.5 I don't know how you would go about it, less room for sure.
I did some searching in the 1994 LH FSM. Should be very similar to a 1996 if not the same. Chapter 19 is the only one that appears to outline getting to the steering rack and the inner tie rods. If you want I can host that chapter and link to it for you. It's in PDF format.
Browsing through it it indicates you do have to take the wiper arms off along with the cowl and the wiper assembly to get down there. Let me know if you want me to host it for you.
Discussion Starter · #13 ·
Still doesn't say anything about how to remove the plastic air intake plenum. I'm assuming I'll need to remove the junction box in spite of it all (looks like it has been removed before judging by one of the missing plastic fasteners).
I can loosen the plastic plenum from the metal air intake ports, but there is not enough of clearance to remove the plastic plenum itself.
It shows the air intake tubing being removed in figure 4 of that section I linked to. It's on page 20. The step just before that is removing the "Cowl Closure Panel" by taking out six screws. That panel is shown in both of your pictures over the intake tubing. It looks like if you remove the cowl closure panel you'll have room to get the intake tubing off. You'll need to remove both wiper arms first to get the cowl panel off.
(6) Remove both wiper arm assemblies from wiper
arm pivots.
(7) Remove the 6 screws attaching cowl closure
panel to cowl. Remove the cowl closure panel and
weatherstrip as an assembly from the cowl (Fig. 3).
(8) Disconnect air plenum from throttle bodies,
PCV make up air tube and idle air control motor.
Remove plenum from the right side of the vehicle
Garfield Rules
I had a 3.3 so I'm not 100% positive with the 3.5, but there should be 2 clamps (1 per throttle body), then take it of the air box, and it should come out. I would also suggest you to remove the cowl, and whole wiper assembly to gain easier access to the tie rods. Also get the 2 piece Moog bushings they last longer and are a lot easier to install.
On a 2nd gen (1998-2004) it's impossible to change the bushings without removing the wipers and wiper cowl. I'm betting it's more so on 1st gens (1993-1997) with the addition of having to remove the wiper motor/Linkage.
With a 1st gen with the 3.3 it's similar to the 2nd gen with the centralized throttle body location.
Discussion Starter · #17 · (Edited)
Are any of these (removable) panels made out of metal?
The reason I ask is because the plastic cowling is attached to a metal piece protruding over the firewall, and it (metal) looks permanent.
EDIT: I was going to post some URLs, but I can't until the 10th post.
Fig 4 on page 19-20 shows a 3.5L air tube being removed. Did you read through the whole process in that PDF? The Wiper Assembly is the metal plate you're talking about.
Garfield Rules
The drivers side of the upper firewall is the wiper assembly it can be removed. I also almost forgot only do one at a time there is a spacer inside the tube on the rack. if you remove both tie rods there is a chance that that spacer will move and it is next to impossible to get back lined up.
It isn't that bad of a job - figure out what is in the way.
As they say "Get-R-Dun"
1 - 20 of 34 Posts
