hello, my 03 3.5 190,000kms makes this terrible grinding noise when trying to start, replaced the starter with no difference, ringgear teeth and starter teeth looked okay, if i rotate the motor by hand about 1/4" it might start but still sounds bad, put a wrench on the front crank bolt and can turn the motor over no problem, if i do get it started everything sounds great and the trans works fine,
today someone said it's the ringgear"cracked"
any advise would be greatly appreciated
thanks, Bill
thanks, Bill
