1 - 1 of 1 Posts
Just wondering if parts for a 1G are the same as a 2G?
http://cgi.ebay.ca/Ball-Joint-TIE-R...ryZ33580QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
You are bidding on a front suspension and steering kit that will fit the following vehicles.
Dodge Intrepid 1993-1997.
Chrysler Concorde 1993-1997.
Chrysler LHS 1994-1997
All the following high quality brand new parts are included.
1 Left Lower Control Arm with ball joint and bushings.
1 Right Lower Control Arm with ball joint and bushings.
2 Outer Tie Rod Ends.
2 Inner Tie Rod End Bushings. (Bushings only, that is all that ever wears out on these)
2 Sway Bar End Links
In this auction it says from '93 - '04 for the ball joints:
http://cgi.ebay.ca/2-Lower-Control-...ryZ33583QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
1 - 1 of 1 Posts
