I just replaced my lower intake manifold gasket. New ignition coil, new plugs, good wires.
The car starts low and rough and then idles around 900-1000. When I start unplugging injectors while idle only bank 1 drivers side injectors affect the idle. All 3 bank 2 passenger side injectors do nothing. All injectors tick when idle.
The manual says there are ground wires on the intake manifold but I don't have a clue where they would be. So they are most likely not Installed but I cant see any loose wires that would need to be ground either.
The first step in the haynes manual says to check the intake manifold grounds though I have no clue where these would be.
Please halp.
power is constant on injectors.
ground is controlled by the computer.
first thing would be to check for power at all injectors, then check to see if you missed a plug in anywhere.
how seperated did you get the harness?
could you have reversed the sides the injector wires belong to?
Discussion Starter · #4 ·
Thread closed was solved in a different thread where I was more descriptive. If a moderator could delete this thread that would be wonderful.
