Hi
I never gad a battery bracket so I used a short trucker type bungie cord - alas 4 years on - the rubber has now fallen apart. So is this the right bracket (photo) and can I just get 10mm bolts at home depot?
Data transfer cable Font Usb cable Parallel Rectangle
also I see that there is a small bent bracket for wiring - not sure if I have it or if it is needed - see photo below...
Arm Tool Font Automotive exterior Bumper
That is the correct battery hold down. Factory bolts are M6x1, 25mm long.
That wiring bracket is described as "BRACKET, Battery Wiring, Remote Battery Post Positive" - should be close to pos. battery post, pos. battery cable is probably secured to it (I don't have a car to look at the details). I'd be surprised if that is missing from your car - not something anyone is likely to mess with over the life of the car.
