I couldn't find the answer on this site, but if it is there somewhere don't kill me.
Can a BCM from a 93 Vision with a 3.5 be put in a 94 Intrepid with a 3.3?
The Vision has Otis, RKE & a factory alarm. I'd like to get the RKE & Otis running the alarm would be a bonus.
Also, did Chrysler make 1994, 3.3l Intrepids with Otis, RKE & a factory alarm?
:dance2:
Well it looks like I might be putting in BCM, PCM, TCM and Autostick from a 97 Intrepid Sport that had a 3.5. The reason for the PCM is to get rid of the speed limiter, BCM for OTIS and the TCM for the Autostick. Will I need to have trouble codes read by OBD1 or OBD2?
Dain bramaged
you cannot run a 96-97 ECM for a 3.5l in a 93-95 car.. Specially not one with a 3.3l
so many reasons it won't work..
1. motors are totally different..
2. 96-97 are obd2 cars and have more sensors then obd1 cars
just a few..
Can you put in the BCM & TCM (for autostick) from a 96/97 3.5 into a 94 3.3?
Thanks!
