181 - 200 of 304 Posts
Bitches be like...
Discussion Starter #181
Ok, so I couldn't get a ton done tonight but I was able to check timing, take a look. Found TDC in cylinder 1 (timing belt side) with a screw driver and tweaked it in as close as I could get it watching the end move:
looks dead nuts to me
Honestly hard to tweak in with the screw driver I landed about -1 to 4 degrees on several attempts. The last time it landed right there.
aimed at Cyl 1.
So we can rule out timing as the issue
Tomorrow I'll pick up a spark tester and rent a fuel pressure gauge, and maybe a compression tester. Seems like the cylinders are getting quite a bath in fuel, so I'm thinking at this point it's electrical.
get off my lawn
you may want to pull the plugs and squirt a little oil down each cyl,, and spin it a few times,, dont need raw gas washing off the rings
Bitches be like...
Discussion Starter #187
good idea, I'm gonna change the oil too anyway.
Your rotor looks pretty crappy from here (...600miles away so thats probably BS)
good luck man!
That's been the prevailing opinion, new rotor and cap ready to go on.
Nate, if she starts giving you crap, just show her this video...
:glum: God that thing was rust free, even on the bottom... what a crime!!
not much left on it,
everything is butchered up, cut and yanked apart, turbo gone ecm gone,, sigh
Ug. what a shame. nothing worth grabbing eh?
Bitches be like...
Discussion Starter #191
Ok. changed the oil and dropped a strawfull of oil onto the rings through the plug holes to try save my rings. The oil was pretty bad already. I hope I didn't do any real damage. to new cap and rotor, with the help of my 4 year old (poor guy can hardly turn the key) I checked spark at the end of the coil cable, seemed consistent, but I could only pull it away from the ground about 3/8 of an inch. Put the ignition tester on the plug wires, 1st one good at 25KV, 2nd one nothing (the second time I got poked too, I think through the frame) 3rd it fired once, but again, nothing, 4th nothing, back to 1st nothing. Went back to the coil again and let it run longer and noticed it seemed to be skipping every now and then, still couldn't pull it further away from 2 different grounds.
so... bad coil?
Bitches be like...
Discussion Starter #194
So here's the synopsis of my current debacle:
Engine is flooding badly on cranking, really bad. I can get a few puffs but then the system is buried in fuel and won't start... plugs foul within 10 seconds.
coolant temp tested, good
new rotor and cap.
Plug wires tested good
new plugs, properly gaped.
All grounds seem good.
coil tested good, 12V with ignition, - side is alternating with crank as expected. Getting spark at the wires.
Nothing is 180 out of time, guaranteed, possible off by a tooth somewhere, but sure seems good.
pulled fuel rail, cleaned injectors. cranked car with rail out, pattern and sequence is good, but it's sending a ton of fuel through, like full WOT fuel.
pump is NOT priming fuel pump on key turn (not until crank)
Manual actuation of ASD relay is providing erratic results in the engine bay... fan kicking on and off, other solenoids opening and closing, erratic operation of the fuel pump.
fuel pressure at the rail is good, pressure dropping after the pump is off at a rat of about 10 psi every 15 seconds (unknown if that is bad)
Compression numbers on a stone cold washed down engine Ver y strange numbers)
Cyl. 1 - 150
Cyl. 2 - 110
Cyl. 3 - 150
Cyl. 4 - 110
So yea... no idea... iz broke.
Bitches be like...
Discussion Starter #196
Do you have a harness / computer mis-match? Sounds like a computer that isn't happy, or maybe you have a really dirty ground or bad cable...
My thought exactly, I cleaned up the computer ground, and the ASD operation is 100% consistent now. The compression numbers worry me, but I think I might put it together and see what happens.
1st Gen FTW - It's AutoMedic!
I know next to nothing about the 4 popper you have there - but what about removing the valve cover and using your eye to check timing that way? Maybe you'll see that a valve isn't completely closing or something?
What's that Clanking/Wheezing noise?
