01 Concorde 3.2, 164k miles
My belt seems fine and is mostly quiet but it’s irritating when I turn the steering wheel and hit the stop and then the belt squeaks until I let off the wheel. Does this mean the tension is slightly too loose on the belt or? Thanks for your help
You could tighten the belt OR stop holding the steering wheel against the stop.
no, the tension is just right to keep you from burning out your pump by holding t on the lock.
Squealer!
When you turn it against the stops, an over-pressure relief valve opens to bypass flow going to the rack. If that valve wasn't there, pressure would go thru the roof and would blow a line or a seal (and it wouldn't be ice cream). The relief pressure of the valve is much higher than line pressure when the steering is operating normally (not against the stops). So a belt that's just tight enough to not slip in normal operation will slip when turning against the stops and opening the bypass valve.
Discussion Starter · #6 ·
Okay thanks. I wasn’t holding it to the stop intentionally, was just trying to determine if it was something I needed to check out. Appreciate the explanation
as long as i's not slipping or sqealing otherwise, it's at a tension that's fine in other words.
too much tension is hard on things.
