G
Guest
·I'm under the impression by looking at pictures and looking at the tabs before I replaced the bushings, that the tabs are meant to be bent over top of the flat sides of the bolt to hold it steady from moving. I can only attain this same placement with a torque of 50 or so ft-lbs and cannot get it tight enough to where the tabs line up to the flat sides to properly secure the bolts from moving. Does this matter? Or can the bolt be almost any angle from the tabs and it will still perform its function.
