1 - 18 of 18 Posts
Interior Modifications:
Modifications from 300m and various vehicles
150mph EL glow gauge cluster from 2004 Chrysler 300m Special
Leather console lid from Chrysler 300m
Slate vinyl-wrapped knee bolster and glovebox from Chrysler 300m
Slate center console with auxiliary 12volt from Chrysler 300m
Lighted visors with pull-outs from Chrysler 300m
Chrome door handles, window switches, and door lock switches from Chrysler 300m
Chrome shift knob from Chrysler 300m with white stitching by Dan (Captainmorgan)
EVIC heads up display from 2004 Jeep Grand Cherokee
Red Illuminated Key ring from 1st Generation Dodge Intrepid
Black rear door smoker's package ashtrays from 1999 Chrysler Concorde LHS
Radio knobs adapted to manual temperature control knobs from a 2009 GMC Acadia
Modifications from Intrepid
Auto-stick shifter assembly and bezel from 1999 Dodge Intrepid ES
Auto-dim mirror from 1999 Dodge Intrepid ES
Dashboard bezel with pocket from 1998 Dodge Intrepid ES
Molded cupholder from 2004 Dodge Intrepid ES with led lighting
Black interior, power front leather seats, and 60/40 split rear leather seats from 1999 Dodge Intrepid ES
Black carpeted rear deck with car-seat anchor delete from 1999 Dodge Intrepid ES
Electronics and ICE
Bullydog Watchdog monitor 40040
JVC KD-AVX2 entertainment head unit
Ipod integration in center console
800 watt DC to AC power inverter under the passenger's seat.
Tom Tom and base mounted next to gauge cluster with hidden wire
Cobra radar and laser detector with hidden wire
JL Audio 250/1 v1 mono subwoofer amplifier
JL Audio 12w3 v3 single voice coil 2ohm subwoofer
Custom one-off box and amplifier rack
Cool-white LED map and courtesy lamps
FAZE electroluminescent volt and transmission temperature gauges
Custom built A pillar twin gauge pod
Custom built steering wheel panel bully dog mount
“Big-Three” battery to alternator, battery to ground, and engine ground upgrade to 2awg
Exterior Modifications:
Headlamps, taillamps, and lighting misc.
One-off OEM retro-fitted fiberglass projector headlamps painted stone white pearl
4300K HID kit
Nokya 55 watt hyper yellow 9005 high beam bulbs
Sylvania Silverstar “blue look” 1157 front turn signal/parking bulbs
One-off fiberglass eyelids painted stone white pearl
Fog lamp housings painted stone white pearl
Nokya 35 watt hyper yellow H3 fog lamps
Tinted taillights with custom “Gears of War” 3rd brake lamp logo
Reverse Fog lamps hidden behind rear bumper
LED license plate lamp
Body modifications
Front bumper from 2001 Dodge Intrepid ES
Bumper-mounted Dodge Ram badge from 2006 Dodge Avenger
Two-tone stone white pearl and black paint scheme by Jake of (Extreme Restorations by Jake)
35% front window and 5% limo black rear windows by Jeremy of (Pro-Tint)
Metallic Gold painted calipers and rotors
18" Stone white w/gold pearl Charger RT rims.
“DTM Style” Stainless steel muffler and 2.5” Thrush glass-pack
AVS Ventshade vent visors
Stubby antenna
Smoked and Stainless Steel license plate cover
Turn signal mirrors painted stone white pearl from 2002 Chrysler 300m Special by (Extreme Restorations by Jake)
Powertrain Modifications:
3.89 Transmission drive gears by (Ron's Tranzman)
Rebuilt A606 Transmission with upgraded clutch material (green) by Ron (Ron'sTranzman)
Custom cat-back exhaust (y pipe, thrush glasspack resonator, DTM muffler) by Chase
3.5L High Output motor from 1999 Chrysler 300m by Dan (Daytrepper)
Akebono ProACT front brake pads
Polyurethane front sway bar bushings, front tension strut bushings, and inner tie rod bushings
Rubber spring isolators
Chrysler 300m “PHP” vented rotors
Wow, just wow. I still can't believe it used to be a normal SE. Ali, looks amazing bud. I cant wait to see it again with the new rims!
frickin awesome ride Ali!!
Discussion Starter #14
Thanks alot Will, I can't believe it was an SE either! I guess 4+ years and boredom changed the car around a bit lol.
Looking really good Ali, love the rims!
Thanks Steph!
Thank you Craig!
Wow your car has come a long way Ali! Those white wheels look great! Can't wait to see the next round of mods!
-Dino
Thanks Dino, I can't wait to start on the next round, going to wait till springtime hits and then sanding/sanding/and more sanding lol
wow that llooks good, cant believe i havnt seen you around town ever
Thanks bro, I drive through Detroit every so often, usually when I'm buying **** from craigslist lol.
1 - 18 of 18 Posts
