i need to know where the blower motor is on my car. mine is making a hell of a noise i im going to replace it. is this a simple procedure or is it a *****. anyone??????? thanks
It's located inside of the lower right air duct (below the glove box). The air duct is held in place by plastic clips. Disconnect the wiring to the blower motor resistor, push the harness gromment throught the blower cover, remove the screws holding the blower motor cover. Remove the 3 screws and pull out the motor and fan assembly. REMEMBER: If the fan is damaged in any way, shape or form, both the fan and the motor need to be replaced. Good luck, and let us know if you have any problems.
thanks crombie....ill make sure to vote for you next time,,,ahh wait never mind hehehe. thanks bud
