Well, even if you could change the stock programming in the computer (for some cars they make programmable ECU's. Check out AEM's Web site...they have some nice programmable ECU's there.....) you would still have the problem of the MAP sensor not being able to read any boost you put into the intake manifold. This means you would need to replace the MAP sensor with a boost gauge, and then reprogram the computer. Like I said, apparently ASE chips cannot re-program the computer like this (I've asked). Not sure if any other of the performance chip makers can do it, but I know that IF AEM makes a program that will run on our car, with their programmable ECU's then you could do it, providing you could mate a boost sensor with the plenum...And then you would probably have to change the piston rings, and so on.....
