1 - 13 of 13 Posts
· Registered
Has anyone ever attempted to bore and stroke the 3.3L V-6 in an Intrepid? The Chrysler 3.8L V-6 used in some of the older minivans is basically an bored and stroked 3.3L. Can anyone think of any reason why this wouldn't work?
The reason I ask is that I fear I may need to replace the head gasket on my 1993 Intrepid ES with 129,000 miles. While I have my engine half-apart, might it be not too much harder to perform this change and add a little oomp to this slow car?
Thanks.
· Registered
the only thing i would think is that maybe the computer will **** a brick trying to sort out what changes were made.
· Registered
computer should really have no reason to **** a brick, because the only thing in there that I could imagine being Mucho different is the Rate of flow for the air. and the MAP sensor takes care of that. Might be a little tough on the tranny, because the shift points are geared for the lower HP.
· Registered
Besides the trans will learn new tricks when it's up and running again.
Personally, I'd look into Bagging a 3.8 from a Town and Country or Dynasty if I could. I think they will bolt in O.K. I could be wrong though. Boring the block is straight forward, but to "sroke" it you'd be better off getting the bottom end of a 3.8 anyway. That way the crank and pistons and rods are all correct rather than choosing a special oversize set.
What makes you think you popped a headgasket?
· Registered
Why not get the head gaskets changed. $800 at your Chrysler dealer if you get both done. Then sell the car, and get a 3.5. You could put the extra few grand you would spend on mods into a better car.
· Registered
on the 3.5, the head gasgets cost MUCH MORE to change than that. Upwards of $2000 from the dealer. how can the 3.3 be so much less?
· Registered
Chrysler dealer here in town said it would be over $2000 for the head gasgets. They Said $700 for just the water pump. Parts alone for the 3.5 (head gasgets, other gasgets needed for chainging) are $300+ if you go all aftermarket. add in water pump and timing belt ($120+), tensioner pully (if needed, $50). Took mine to a garage instead, got the price down to $1500 to get it done (including Cutting the heads and cutting the valves/valve seats). Couldn't justify $800 and 3 weeks or more of my own work outside in the Cool wisconsin fall to do what they got done in 4 days.
· Registered
Discussion Starter · #13 ·
My mechanic is telling me $1200 to fix head gasket. Says coolant is leaking out. I have been experiening shitty power delivery possibly because leak of coolant into cylinders? Car goes to mechanic for further inspection tomorrow.
1 - 13 of 13 Posts
