1 - 10 of 10 Posts
Can anyone recommend a good Bug & Tar remover? Now that Spring/Summer are here in the South the bugs that are the size of small birds have decided to cross the road and met their demise on my front bumper. I remember using something years ago that almost seemed petroleum based and left a film unless the car was washed. So if anyone has some experience/advice...let me know. Also if you can let me know where you purchased the fabulous product that would be appreciated. Thanks.
Turtle Wax makes a product that is called....you guessed it....."Bug & Tar Remover". anything you use to remove bugs is going to also remove wax. So give it a good wax job when your done. A good waxing should also make it easier to remove the bugs next time. Do you know what the last thing to go through a bug's mind is when it hits your windshield ?????
"I don't have the guts to do that again"? Literally. Thanks for the advice.
good guess, but the correct answer is "it's ass hole"
I thought Ass**le was for the guy trying to hi-jack my WTB thread for one MS wheel?
I'll check on the brand later if I still have some left but I bought this aerosol bug & tar remover at advance auto and it was awesome. It was citrus based and worked well on both bugs & tar, and I used it to remove the adhesive left behind when my hood badge fell off and it worked really well on that as well.
Look for a "solvent" type product, I'm pretty sure meijers carries something called "Bug, Tar, Wax Remover" that stuff should work. Or if you want the "professional" stuff, buy a bottle of meguiars solvent, its what I use at the stealership (ours is a different brand but its the same ****) spray the solvent on, let it soak for a couple of minutes and then lightly brush the stuff off, or rinse it with some pressure from the hose.
Well I dont know if it was very good for my paint or not, but there was no bug and tar remover that was working for me so I said eff it and used windex. Worked great!!! took every little bit off even the crusty week old bugs that were super juicy at first.
Thanks for the tips everyone. I'll try the Windex route and see what happens. I have plenty of that. The only thing I'd worry about would be the ammonia in the Windex might take off the wax. But it's time to give it a few new coats on the bumper anyway. Thanks again.
Pretty much anything that removes bugs & tar, including the commercial stuff, will remove wax anyway so I would definitely try the windex idea.
1 - 10 of 10 Posts
