1 - 2 of 2 Posts
I need to replave the one of my air conditioning lines because it is leaking, it is the line larger line that runs from a square box on the firewall to a small black cylinder right next to the condenser. The problem is that I am not sure how to repalce it do the lines seperate somewhere or do I need to go to a shop and have them make a new line.
The box at the firewall is the expansion valve. The small black cylinder is the drier. Best thing to do is go to the dealer and get a new line from the expansion valve to the drier. There is usually a bolt at each end of the line that you remove to pull it out.-- these should be at the expansion valve and drier, or the line might include the drier with it. If not, its got a quick-connect and you would need the tool to get them apart. Post some pics and I can tell you which...
1 - 2 of 2 Posts
