1 - 20 of 41 Posts
Found out last night how to recalibrate and check your AC and vent system on your Intrepid with manual controls. I found out because while my AC was on, the air coming out of the vents was warm. This procedure fixed the problem.
To do it follow these steps
Set the fan control to low (not off)
Set the temp dial to the coldest setting (far left)
Set the vents to window defroster
Now press the rear defroster button until AC00 appears on your dashbaord then let go.
The car will run it's diagnostic test and recalibrate the dials over the next 1 to 2 minutes.
For all those who are interested the Haynes manual for the car has alot of tricks like. The best manual I ever bought for the car.
Cool trick- I just did that to mine and you hear the doors and vents opening and closing. I think mine is also blowing just a tad cooler and more forcefully out of the dash vents, I wonder is something wasn't sealing properly.
You're f*ckin kidding me... seriously, you have a 2nd gen, right? I ordered one about 6 months ago, the order supposedly went though. I got an email a few weeks later saying it's on backorder, and then a couple weeks later they said it didn't exist. I was pissed off... they took my money for over a month, intrest free. Now to hear they did actually have it... I'm going to call them up and give them a piece of my mind.
Discussion Starter · #16 ·
Check to see if there are any other codes by allowing AC46 to appear then press the AC button on the dash to see the next code. It may be related to another problem. To clear the codes you have to disconnect the battery for 10 minutes.
Let me know what else it says.
I have yet to disconnect the battery. I was going to check if there were any other warning numbers after the AC46. I will be disconnecting it later this week when I change the wires and plugs. I am also going to flush the cooling system.
As for the AC50, the manual reads:
A/C Control Electric Backlight
(EBL) Switch Failure
As for what any of these codes mean, I do not understand.
1 - 20 of 41 Posts
