1 - 9 of 9 Posts
· Registered
where is the camshaft sensor located again? i dont have much time to do anything lately, i just wanted to clean it out real fast sometime this week...see if the car'll stop shaking like a scared puppy. thanks!
· Registered
yes, they are two different sensors. the CAM position sensor is easy to get to, the CRANK is not. my chilton's is in my trunk, otherwise i'd give you the exact location. at any rate, READ the crankshaft thread and you'll see that the topic starter indeed had the wrong sensor named. he was referring to the CAM sensor incorrectly, which is the part that Valhalla wants to service.
· Registered
so which sensor is it that causes the rough idling? My trep shakes when it idles in park, and I was just wondering if the cam sensor was the cause?
Any ideas??
(I keep her well maintained, other than not cleaning the cam sensors)
· Registered
I am not a expert, but I think that the sensor in question is the crankshaft. It is located on the bell housing. If I am not mistaking, it will be located towards the driver side of the car. Jack-up the car and it is located between the oil pan and the bell housing ( transmission? ) From under the car, look straight up and you will see a thick black wire coming like from the upper part of the engine compartment then come down connected to side of the bell housing. You will see this so called sensor at the end. Now here is the problem. You need to have very skinny and long arms to reach this. Also you will need a large open wrench to unbolt the sensor. You will need one that is over 1". My biggest tool is a 1" and it is too small!!! :mad: After unbolting the sensor, you just wipe off all of the **** it has and just put it back on! Make sure that the battery cable is not connected.
Now, I cleaned my CAMshaft sensor yesterday and my car still shakes in idle. The only thing that was accomplished was that the engine light did not come on again. So I guess I am in the right direction folks.
Hey, if anybody thinks I stated anything incorrectly, PLEASE let me know. I am in the process on doing this too myself as soon as I go to Sears to pick up some tools :D :D
1 - 9 of 9 Posts
