I cant seem to find how to put the puictures of my car on the thread
Can someone help
-Thanks,
josh :frown:
once the picures are hosted, right click the picture and go to property's, copy/paste the address of the picture between
Try this:
You have to have the picture posted to a website that can be accessed using BBcode. I use flickr but you can use photobucket or some similar site. Once uploaded, you can add as noted above (just make sure you put the img command and the ending command /img inside brackets:
Flickr gives you two ways to get this. The "first" short code is the result inside the img brackets is above
Just for fun I also copied the complete html code from the flickr website and it prodces the result below:
<a href="http://www.flickr.com/photos/[email protected]/2729308847/" title="Photo_080208_003 by gsaun039, on Flickr"><img src="http://farm4.static.flickr.com/3118/2729308847_b84e3abd2f_m.jpg" width="240" height="185" alt="Photo_080208_003" /></a>
Generating clever phrase...
I use Photobucket. It has the IMG code below your pic and you just copy and paste and it will show up full size.
