Cam sensor, not crank?Strongt said:If the above doesn't work, the cruise light also lets you know that the timing is off. The cruise light will flash if the timing is off. Since you didn't say that it was flashing, I would think it may just be a bad Cam Sensor. Just my two cents.
Cam Sensor, because thats how the PCM knows the position of the cam's so the PCM knows that timing of the engine. Yes, the Cam Sensor, and Crank do work together too, because the PCM needs to know the position of the crank also for the timing. But I'm betting on the Cam Sensor because just about everytime the timing is off ( like when the timing belt is about to broke, or skipped a tooth) The PCM lets you know through the Cruise Light. One question though, you said that the car has been running rough lately. And I know you just changed the timing belt awhile back. Do you think that maybe one of your Cams is off just alittle? I think there was a member that had that problem when he changed he's timing belt too. I'll do a search and see if I can find it for you. Maybe something else to think about also.Ryan D. said:Cam sensor, not crank?
