Last year, I put new Bendix rotors and Bendix CT-3 ceramic pads on the front wheels of my 04 SXT with chrome wheels. I've heard many positive comments on the forums about this setup. However, a week or so after cleaning, I start to get heavy, black dust on the wheels. The OEM pads created dust also, but never this dark. I thought ceramics were supposed to be less and/or lighter dust.
Has anyone else experienced this with these pads?
Along with this, the rotors have warped and the brakes squeal under certain conditions. I plan to get the rotors machined once and see how they do.
krusty1
krusty1
I always use ceramic pads. When they're new you don't have any problems after a few years then you might see some dust build up time to change them again. Wagner Gold worst pads to get they're bad with dust.
First thing that came to mind is that if you use tire shine and get it on the wheels, it will cause the dust to stick.
It also depends on the formulation of the ceramic material. The Bendix pads i had on my Eclipse produced a light grey, almost white dust while the Axxis ceramic produced a heavy black dust. The Axxis did bite a hell of a lot better than the Bendix did though.
Discussion Starter · #5 ·
These Bendix pads are causing dirtier wheels than the OEM pads. I guess I was a little surprised. Maybe it's material from the rotors...
The term "ceramic" is wide open. An engineer at Frozen Rotors told me that a manufacturer could literally put a pinch of ceramic dust in their mix and call the pads ceramic. Saying a pad is ceramic is little guarantee of anything.
