1 - 17 of 17 Posts
probably an hour of labor. $77 bucks.
if you have the oil and filter i'd just take it to a mom and pops shop and have them do it. shouldnt be anymore than $15-20 bucks.
I just wish i could go into midas or somthing and just ask if i can use one of there lifts lol. Yeah i will just call then.
Why not just do it yourself then? All you need is a jack and stands or ramps and a drain pan
I was thinking the same thing but it may be a weather issue like I have with mine sometimes. Really sucks not having a garage when you want to work on the ride during the winter. And I really do not get the bad weather down here in the south.
i would consider one more oil change at a "shop" (because of weather??) and that will hopefully get you through until warmer/nicer weather. then invest in jack and jack stands, oil drain pan, oil filter removal tool, and start doing them yourself!!! switch to synthetic (mobil 1 5w30 5 quart jug ~$22 at walmart) and pick up a filter from parts store. cost about as much as a "cheap" oil change from a shop. it truly is not that difficult...
Whiskey Tango Foxtrot, Over!?
I have mine done at the dealer and it only runs around $26...
We want to be your dealer for life......
Most dealers will kill to do an OLF. It is an excellent opportunity to "assess your service needs". LOL
"Whiskey Tango Foxtrot, Over!?"
I like that! Never saw that before....
What makes you think the monkeys at the dealer will be any better than anyone else?
Just buy ramps at Advance for around $40...and do it yourself. Much easier.
Discussion Starter #13
Well i ended up going and it was only $10.79 with my oil and filter already with me. I would change my oil myself like i always do but its been very cold and with snow on the ground it makes it worse.
THATS CHEAPER THAN WAL MART!
impressive.
dealers dont cost that much, prob 20-30$ max to change it for u. This isnt a lambo guys.
Regular oil changes are like 50$ complete.
CM
Do it flat
This is a minor point, but you don't need a ramp or jacks to change the oil, at least in a second generation. I do mine with the car flat on the ground all the time. I would never get under a car up on jacks or jack stands, and probably not even if it were up on ramps. Too much can go wrong.
1 - 17 of 17 Posts
