1 - 1 of 1 Posts
Hi! I have a couple questions, I put a water pump in for my sister on her Dodge Magnum with the 2.7, I got everything back in properly, but I really needed a new tensioner and even told her that, Just didn't have the funds, so we get it all back together and it runs fine for a little bit (around 30 seconds) Then sputters, stops, I tried to start it again and felt something was off, so we've left it alone, I think it may have jumped time a couple of teeth, so I'm going to redisassemble everything, and do it properly the 2nd time. (You always got time to do it right the second time), My question is this though, if it did jump time and I need to retime the engine, How would everything line up? Would it just be the same pull everything about, time the cams to the crank and golden?
1 - 1 of 1 Posts
