1 - 2 of 2 Posts
Site wouldn't let me post in the LX Section so I'll post this here:
Chrysler recalls sedans, Jeeps
45,000 Chrysler 300, Dodge Charger and Dodge Magnum sedansneed repairs to prevent brake fluid leakage
Ken Thomas / Associated Press
WASHINGTON -- DaimlerChrysler AG said Friday that it was recalling about 45,000 Chrysler 300, Dodge Charger and Dodge Magnum sedans for repairs to prevent brake fluid leakage that could lead to engine compartment fires.
DaimlerChrysler said the recall affects 2006 model-year vehicles with 2.7 liter engines. In some cases, the exhaust gas recirculation tube could come into contact with the brake tubes, leading to brake fluid leaking and a fire.
DaimlerChrysler spokesman Max Gates said the automaker was aware of nine reported engine fires. He said there have been no reports of crashes, injuries or property damage.
The recall will involve inspecting the rear brake tubes for damage and replacement if necessary. Technicians also will install a clip on all the vehicles to secure the brake tubes and maintain proper clearance from the exhaust tube.
Gates said owners likely would be notified later this month.
DaimlerChrysler also said it would recall nearly 7,000 2006 Jeep Wranglers equipped with 6-speed manual transmissions because of potential problems with the clutch.
The automaker said the hydraulic clutch master cylinder rod could break, which could make it difficult for the clutch to disengage when the pedal is depressed.
Gates said the defect could prevent movement, lead to increased stopping distances and engine stalling. The company said it has received 17 complaints and no reports of crashes, injuries or property damage. Owners also are expected to be notified of the recall later in the month.
In both recalls, the vehicles will be repaired at no charge to owners.
Edit: Sorry for the double post, the server is being slow.
Saw that fried charger pic... could be related...
1 - 2 of 2 Posts
