im doin my oil change today n i also picked up a can of seafoam deep creap... my question is where it the idle air controller? ive read that i should spray it in there... and should i do this before or after i change my oil?
the IAC is on the throttle body...where else would it be? :)
The 3.3 regular fuel engine does not have an IAT only the 3.5 & 3.3 Flex Fuel. See e-mail from Chrysler below:
We have received your email dated February 2006 and appreciate you
contacting us regarding your 1994 Chrysler Intrepid engine inquiry.
The 3.5L engine uses an IAT sensor, however the 3.3L does not. As your
vehicle was originally equipped with a 3.3L gasoline engine, it does
not require an IAT sensor.
