will regular carb cleaner hurt the upper intake manifold? i know carb cleaner is bad for plastic. i have the intake off and want to clean it up.
Stand it up, let all the oil drain out (few ounces), clean the heck out of the throttle body (might want to remove it first). Replace the PCV afterwards.
carb cleaner eats some plastics so try a little on an area you wouldent mind if it go a bit melted and see what happens. If in 5 mins the plastic looks good, hose the sucker down :)
Brake parts cleaner? Dishwashing liquid?
