whats up guys can someone help me with my fron headlights on how to clear the turn signals i dont know how and if there is a way can you help me or is there a place where i can buy them???
There's always a way, I just have no idea what it is! Since your car is a 2nd gen you might try asking them, or maybe a mod could just move this thread over there
Well this is the wrong section, but I can help you! There is no place that sells headlights with clear corners, but there is a way to remove the reflector. To do so you must tear the headlights apart. There is a good write-up in the how-to section, by Skuby INC, which will tell you how to tear the headlights apart. Here is a link to that how-to: http://dodgeintrepid.net/forums/showthread.php?t=49202
Once you have the headlights apart you will need to remove the piece that stays in the cover of the headlight. All of the chrome pieces inside of the headlight assembly scratch VERY easily so be VERY careful. Next you need to drill a small hole in the amber lens where it attaches to the plastic piece. This should cause the reflector to come off...you could also use needle nose pliars to break the reflector and use a dremmel tool to remove the pieces of amber lens that remain on the assembly.
There is another way to do this mod, but I think that this is the best way since you will not need to drill holes into the lens. This way requires you to drill holes where the lens is glued onto the assembly then you use needle pliars to break the lens and remove the pieces through the hole where the turn signal bulb goes. This might be the easiest route because you do not need to take the headlight apart, but it will not look as clean when you are done. Here is a how to by Slewis which will show you how to clear your corners without tearing apart the headlights: http://dodgeintrepid.net/forums/showthread.php?t=34461
Hope this helps you!
www.procarparts.com sells clear turn signal housings for the front for 1st gens for about $50 w/shipping.
