I have a 2000 Intrepid 2.7L with manual climate controls. You know the three knobs... Well... AC and heat work, but not correctly...
The heat really never turns off on off... and not to mention the heat only works on defrost... and the AC only works when I put the blower knob to a perfect setting between "high/low" and whatever is next to it... its weird...
So when I put the blow vents to "high/low" the ac will work and it does blow high/low... but i can never get anything out of the front vents...
when i turn it on low and rotate the blower knob i can hear something shifting in the back and moving but air doesnt come out...
im thinking the middle controls just need to be replaced? or since the car was in a minor accident at one time someone took apart the dash and forgot to hook a belt or something when putting it back together?
Let me know if you know of anything please! Thanks...
Joe
Joe
