I was coming home today and all of a sudden CHECK ENGINE light pops on. I cycled the ignition and got a code 12 (like always) and a code 31.
According to the Haynes manual, a code 31 means "Problem with the canister purge solenoid circuit." I don't know where to start with this code. Could it be any more vague?
I found a diagram on page 6-18 that explains the EVAP purge solenoid and where it is located. It states in the manual "The EVAP system won't fail during the service life of the vehicle; however, if it does, the hoses or charcoal canister are usually to blame." Do I start chucking parts at this area of the engine? I need some input here.
I am wondering if any of you guys had this code and what you did to correct it. Is this a serious problem? Thanks.
