hey guys, ive been having problems with my IAC valve, ive had 2 that where bad.
well i got one that i think, finally works, but now my check engine light is on and i forgot how to read the codes, i made a video of the light blinking, can yall help me out?
12, 24 and 55.
12 is the battery disconnect code and 55 is the all finished.
24 is the throttle position sensor is above/below acceptable limits. Also does the car not shift into OD, or downshift when you floor it?
Discussion Starter · #5 ·
I drove mine without it hooked up and thats what it did. I don't remember it causing idle problems though.
i just drove it after disconnecting the battery, and it fixed the prob. i think it happened when i accentually unplugged the TPS while it was running. it down-shifts fine now and not having any problems :)
