I have seen a lot of post with the 3.5 having a cold start problem.
I was just checking to see if any body that posted about it before or read about it has found or fixed the problem. For every body else the problem I am talking about is after the car sets for lets say 1 hour or more it takes 5-10 secounds to crank and start.
After it starts it will keep on starting up just fine untill you let it sit again. I have a egr code but I was told this is not the problem and I do not think it is ether. Any replys would be helpful
Thanks
I have a 2.7 and I am begining to have cold start problems but only if it sits for at least 4-5 hours. I only have 52k miles so I refuse to believe its the spark plugs or battery. Has anyone figured out the problem?
:alien:
So, no codes, How long are you planning to go with the same plugs?
