Can someone post for me a picture of the back of 96 Intrepid AC compressor.
Something spews out the back of mine from a hole in back that is treaded as if a screw goes there. Any ideas or pictures world be appreciated.
Ok, look at the pic below, is the hole that your talking about right next to where the arrow is pointing that says " compressor manifold "(the right side of the arrow), if so it's a high pressure relief valve. You may just need a new one.
The high pressure relief valve is located on the A/C compressor manifold.
Take the vehicle to a certified shop to have the system discharged properly.
Rotate the high pressure relief valve counterclockwise and separate the valve from the vehicle. Discard the old O-ring.
To install:
Lubricate the new O-ring with engine oil, then install it on the valve. Rotate the high pressure relief valve clockwise and attach the valve to the vehicle. Tighten the 5/8 inch hex head to 10 ft. lbs. (13 Nm).
Properly charge the A/C system.
My hole is more like where the 1st R is in compRessor but on the back side meaning the opposite side of the clucth. There is no valve there to adjust, is this the right area
Well, thats weird, I don't have anything on the back of mine. It's just a solid piece, no holes or anything.
Looking at my compressor again this morning i see that the hole is that valve to right of your arrow. Can this valve be purchased and can I, the average tinkler replace it?
Never mind I see you say remove the valve take out the o ring and replace.
Is there a part # for the o ring or are they all the same?
If you take the old O ring to a parts store they will be able to get you a new one for a buck or less. Just remember to have the system discharged BEFORE you take that valve out.
that is if its a standard o-ring. if not it might be a dealer only item and cost a couple arms and a few legs. I dont have A/C on my car so I cant help much more than that.
After I get the system discharged do i need to replace any other parts to complete the job?
