Purchased car and temp gage would hit max........changed temp sensor and th8ng that come with it and it worked perfect for months..not gage is going back to max and says i need fluid......blead the fluid and purchased 2 gallons......gage went to the max again this morning.....when it says its overheating the car actually does not overheat...fans are working properly......if i turn of car for 30 seconds and then the gage will go back to the middle....but the gage just keeps bouncing...my heat works fine....
