Yesterday my A/C dropped out on me suddenly. Blower works but the air is hot. Basically, the compressor clutch refuses to pull in. I ran the codes using the key dance and came up with nothing. When I ran the diagonostics on the ATC head it came up with a code 36, communications error. Naturally, I blamed the ATC head.
Today I made it to the junkyard and found a single ATC equipped Intrepid. I swapped this unit into my Concorde and still had no A/C. Got a code 26 (bad thermistor) so I passed on it.
When I got home I decided to dig in a little bit and found the following:
1) When I apply 12V directly to the compressor clutch it pulls in fine and makes cold air. Compressor and clutch appear to be fine. There is no voltage at the clutch connector under any condition.
2) Clutch relay audibly pulls in when the engine is running and the A/C is on. Swapped it with the wiper relay in case the relay itself is bad. No dice. Relay appears to be working properly.
3) Pulled the radiator cover and pulled the connector from the A/C pressure trandsucer. Jupered between the ground and transducer signal terminals and did not see any difference. Not sure if the BCM is looking for a simple closure or a 5V signal from the transducer. Don't want to apply 5V without knowing for sure.
At this point, it doesn't sound like a bad ATC head anymore. It seems to me that if the ATC head was the culprit, the clutch relay would not pull in. Am I wrong?
I don't think the refrigerant level is too low, since the air cools fine once the clutch is forced in. Also, the air worked fine before yesterday. My experience in the past is that the effectiveness of the A/C begins to drop gradually over time before the pressure drops low enough to cut the compressor out.
I'm thinking it's either a bad pressure transucer or a broken wire, but I'm leaning towards the transducer. I don't see any procedure for testing it in the shop manual and don't want to waste the money if it is still good.
My questions are:
1) Anything I missed in the diagnosis? I'm no expert in A/C systems so any suggestions would be helpful.
2) Can the pressure transducer be tested either on or off the car? If so, how?
3) Is there a way to safely jump out the transducer to see if the clutch engages without it?
4) Any chance this is the PCM? I'm hoping not.
Thanks in advance.
My questions are:
Thanks in advance.
